Question on SMTA Diesel
Red Lover
12-31-2005 05:57:21
Hi guys, I need your help. I am restoring a SMTA -diesel that is in pieces. I am putting the throttle lever and linkage back in and have hit a roadblock. I have the throttle lever and the keyed arm that goes on the end of the throttle lever. My question is ---what pilots the lower end of that round throttle lever? Is there supposed to be a sleeve or block or bearing of some sort to hold that from flopping around? As it is now the lever just goes through a large hole in the gauges bracket. Thanks
Roger46
12-31-2005 14:49:32
 Re: Question on SMTA Diesel in reply to Red Lover, 12-31-2005 05:57:21
My MD had a sleeve that was attached to the gauge mount as I remember. The shaft goes through this sleeve and the keyed arm attached to the end of the shaft right next to this sleeve. I can't remember how the sleeve is attached, but I think just like spot welded to the gauge assembly. Your sleeve must have broken off and left only the hole. On my MD someone had converted it to the throttle linkage like the 400D and 450D have, so I had to find the complete linkage in the salvage yard to get it back to original. I was luck to find one and they even sold it to me cheap at $20 for the whole assembly. Roger
