oil filters
Tyler in SD
01-01-2006 17:14:00
Can an element-type oil filter be placed in a filter housing upside-down, causing a lack of oil pressure? Also, can new filters cause pressure loss?
captaink
01-03-2006 08:47:08
 Re: oil filters in reply to Tyler in SD, 01-01-2006 17:14:00
Oil filters are pretty much fool proof. If it makes a difference, they will only fit one way (like on A, B, C, H, M) they are larger on the end that goes into the filter base, the cover won’t screw down tight if the element is in upside down. On the 560, it doesn’t matter, the filter is symmetrical.
billde
01-01-2006 17:45:13
Filter will only go on the bolt one way, will not effect oil pressure as they are a bypass filter.
CNKS
01-01-2006 17:32:21
No to both questions. If I remember right, they only fit one way.
