OT - Perkins S6M engine?
SAm in NS
01-08-2006 15:04:09
Does anyone know anything about the reputation of these engines at all? I know a couple of rough specs and that they were usually marine engines. I was offered one and was just wondering if it wouldn't go nicely into some old tractor. Many thanks, SAm in NS
Jokke
01-09-2006 11:22:19
 Re: OT - Perkins S6M engine? in reply to SAm in NS, 01-08-2006 15:04:09
Look for a Perkins 6-354.
That"s the most common Perkins used in a lot of applications. MF tractors, harvesters, JCB dumptrucks, excavators, wheelloaders,....
P Backus
01-09-2006 11:00:47
If you want to use one in a tractor, make sure the rotation of the crank is the correct direction. From the little I know about marine engines, I know that sometimes the rotation is opposite of "normal". You could wind up with a tractor that has 5 reverse speeds and 1 forward!
Paul
Janicholson
01-09-2006 18:23:43
 Re: OT - Perkins S6M engine? in reply to P Backus, 01-09-2006 11:00:47
Flipping the differential will make it go in the correct direction, (on many tractors is used to make all terrain fork trucks and the like.
JimN
El Toro
01-08-2006 18:49:20
Massey-Ferguson tractors used the Perkin engines
in some of their tractors. I don't think the S6M
was used. IH never used them in their tractors.
Hal
