5288 PTO
Michigan Dave
01-16-2006 19:30:14
Greetings Can a dual speed pto from a 5088 be
installed in a 5288. Thanks Dave
Nat 2
01-17-2006 06:06:24
 Re: 5288 PTO in reply to Michigan Dave, 01-16-2006 19:30:14
No problem. They're the exact same tractor. The only difference between the two is the decals on the hood, and a couple of turns of that magic screw on the injector pump.
Boy what a scam that was... Build the same tractor, slap a different sticker on it, turn the pump up, and charge tens of thousands more for it...
RedToyMan
01-17-2006 17:30:45
 Re: 5288 PTO in reply to Nat 2, 01-17-2006 06:06:24
A number of differences between the 5088 and 5288. The 5288 and 5488 have more in common.
5088 - DT436
5288 - DT466
5088 - Rear axles 3.5"
5288 - Rear axles 4"
5088 - 3pt cap. 7290 lbs
5288 - 3pt cap. 8399 lbs
5088 - 2wd weight 13,765 lbs
5288 - 2wd weight 14,610 lbs
JRred
01-17-2006 13:32:34
Actually the 5088 has a different engine! the 5288 is a dt 466 the 5088 is I think a 416 now the 5488 has the 466 also!!!!!
Steven@AZ
01-17-2006 16:19:26
 Re: 5288 PTO in reply to JRred, 01-17-2006 13:32:34
5088 was DT436
5288 was DT466
5488 was DTI466
MNredfarmer
01-16-2006 19:42:50
yes, I believe you can
