Ahhh we have a problem
Larry806
01-19-2006 19:10:59
Pulled the torque out of the MTA today. The torque clutch & planetary's look like new. Same old story the pins & springs are bad. I call the dealer to order.Gaskets, seals , No problem springs , check , pins , check , rubber plugs , check rollers _____ ___ ah your not going to believe this there NA. just a min I'll just get them through Hy Capacity ahh NA from them too. Some has to have the rollers but who?
Bill in MI
01-20-2006 16:03:47
 Re: Ahhh we have a problem in reply to Larry806, 01-19-2006 19:10:59
Personally we have had good luck with the guy who advertises in the red power mag who is located in PA. His first name is Rich but would proably mess the last name would recomend highly reasonable also thanks Bill
MAGMAN
01-20-2006 15:40:34
The last one I bought was from wengers they got me the whole ramp and tollers ready to install for a 300 for around $150. that was in 1990 or so. JON
ejr-IA.
01-20-2006 11:06:42
Does A&I have those parts I think thats the right name.On our 460 we machined out the old ramp and roller sprag and used a sprag out of a 1066 ta.
Aces
01-20-2006 09:58:51
Larry I never saw a TA with bad roller and not need ramp and carrier as well.
Redrider
01-19-2006 20:12:06
The best thing you can do is replace the ramp and roller assy with a sprag lock up. You won't be sorry. I have replaced the TA in three of my tractors with the sprag and they work perfectly.
the tractor vet
01-19-2006 20:19:26
 Re: Ahhh we have a problem in reply to Redrider, 01-19-2006 20:12:06
If all ya need is some new rollers then why would you want to spend the extra money when they worked with the roller for how many years , the hardest thing on a T/A is not keeping the adjustment up and not changing the Hy Tran . Now if the carrier is chewed up then is the time to replace with a spragless but if it is not chewed fix what is neede and stuff it back together and it's good for another 10-20 years.
the tractor vet
01-19-2006 19:22:59
Timken
Larry806
01-19-2006 19:26:08
 Re: Ahhh we have a problem in reply to the tractor vet, 01-19-2006 19:22:59
Don't happen to have a number do you?
the tractor vet
01-19-2006 19:37:45
 Re: Ahhh we have a problem in reply to Larry806, 01-19-2006 19:26:08
Ya need to getinto the brearing book and go whith the sizes i think that bearing Inc . or what ever they are called this week or bearing dist or may be NAPA.let me look in my Hy Cap book , nope they don't list them anymore just the reman ramp and rollers and the spragless.
Janicholson
01-20-2006 05:54:32
 Re: Ahhh we have a problem in reply to the tractor vet, 01-19-2006 19:37:45
Motion Industries is the Name This week (I still like them, names change but people often stay behind the counter)
JimN
Nat 2
01-20-2006 05:20:59
Is there anything special about the rollers, or are they just simple polished hard steel pins? If you know someone who can run a lathe, and you have the original diameter of the pins, they could be manufactured quite easily.
If you had to pay to have it done, the spragless would probably be cheaper.
It's pretty much a given that they wouldn't make those parts available anymore because very few people would even attempt to rebuild their own T/A, and the rest of the unit is usually tore up anyway.
