RE: 656 Hydraulic leaks
Peat
01-23-2006 16:14:47
Spent Saturday afternoon repairing a leaking remote valve on my 656, based on the posts to this forum seems like a common problem, after the repair started up the 656 to check for leaks and hydraulic fluid started flowing out from the steering wheel shaft???Is there a relief valve under there? The leak stopped when I turned the wheel and hasn't leaked since????
Janicholson
01-24-2006 09:33:48
 Re: RE: 656 Hydraulic leaks in reply to Peat, 01-23-2006 16:14:47
A small piece of junk probably got loose and opened up a leak under an Oring. I would ignore it until it reappears (if).
JimN
