Super C belt pulley installation
Chris in Washin
01-24-2006 00:31:18
Does anybody know how to figure out which shim to use when installing a belt pulley for the first time on a Super C?
achodges1
01-28-2006 15:21:10
 Re: Super C belt pulley installation in reply to Chris in Washington, 01-24-2006 00:31:18
Looked in the I.T Shop book and it said the gear lash should be set at .004 to .006. Didn"t give any more detail that that. Hope that helps. Guess its trial and error.
gene bender
01-24-2006 02:40:55
The shims are used to set the gear lash clearence. If you arent going to use the pulley no need to worry. If it is going to power a belley mower then you would want it set correct.
Chris in Washington
01-24-2006 11:44:25
 Re: Super C belt pulley installation in reply to gene bender, 01-24-2006 02:40:55
Thanks Gene, I do plan on using the pulley and need to know how to properly set the gear contact.
