Clutch arm extension?
chadd
01-27-2006 05:59:08
I was just wondering if anyone has ever seen a clutch arm extension like this and if so, what it was supposed to do? The only thing I can think of is that it would make the clutch easier to push down.
Here is a picture of the arm on our tractor:
third party image
Here is a picture of the arm on a Super W6 (I know they aren't identical, but they are supposed to be similar):
third party image
Yugrotcart
01-27-2006 18:36:55
 Re: Clutch arm extension? in reply to chadd, 01-27-2006 05:59:08
I see them on EBay now and then. I spent 1/2 hr and made one about 4" long for my W6, makes it alot easier to push..... ...
the tractor vet
01-27-2006 09:34:07
That extenshion is a real big help if ya put a 706 plate on a MTA , weput a 706 clutch in my one buddys MTA because that one is the one that we did up and it will walk thru a standard clutch and she is a bit hard to push ya don't want to have to set for vary long holden the cluch down ya get that left leg shake .
chadd
01-27-2006 10:07:55
 Re: Clutch arm extension? in reply to the tractor vet, 01-27-2006 09:34:07
Thanks for the reply. I was also wondering, will that affect the free play of the clutch pedal? It seems to have a lot (about an inch) more free play at the platform than what my service manual recommends. The throw-out bearing is good and the clutch disc has been in a year. I adjusted it the first time with a gap gauge between the clutch fingers and throw out bearing. Should I continue doing this instead of using the pedal measurement?
Janicholson
01-27-2006 16:48:36
 Re: Clutch arm extension? in reply to chadd, 01-27-2006 10:07:55
I would gap measure it one more time then measure the freeplay and adjust to that from then on. It definitely changes the clutch action from stock, pushing all the way is necessary, and the point of engagement may be low.
JimN
MN Scott
01-27-2006 08:06:59
I see them on Ebay from time to time. Most were made by M&W and I think they made the clutch easier to push.
