Could this be..
werter
01-30-2006 14:44:04
I have a Super H with the live Hyd., and it could have been a demostrator because of traces of white on the front grill and along the bottom of the hood. My question is did they also have a lift all belly pump along with the live HYd., this one seems to have, what it looks to be a belly pump. This tractor has alot of problems so Im just salvaging it, but I was just curious about the hydraulics. Thank you
Pat H
01-30-2006 20:54:11
 Re: Could this be.. in reply to werter, 01-30-2006 14:44:04
would like to know the serial number if possible?
are the live hyd's factory or aftermarket - could be aftermarket and use belly pump for reservoir.any parts for sale? email unlocked.white paint could have been done later to immitate the 350 looks. thanks Pat
werter
01-31-2006 07:21:14
 Re: Could this be.. in reply to Pat H, 01-30-2006 20:54:11
Here are a couple of pictures.
third party image
"A" would be the thing in question, "B" is obviously where the resevior for the live Hyd. goes (lying on the ground)
third party image
White paint on the grill.
Pat I dont know what I want to keep yet, but I will keep you in mind when I do. Thank you
pat h
01-31-2006 12:18:45
 Re: Could this be.. in reply to werter, 01-31-2006 07:21:14
CNKS is right with his reply, what looks to be the bottom of the belly pump is just a plate for hooking imps to. I know of a tractor that needs the torque tube from yours, I also need a stage 2 gas tank. Pat
RustyFarmall
01-30-2006 17:11:37
Quite a few Hs and Ms were repainted so they would like the new 350s and 450s, which did have white grilles. There was never a super H demonstrator.
CNKS
01-30-2006 17:03:21
No white H/Super H demos. If it has factory live hyd, there is no belly pump. The cover for the opening may resemble that of a belly pump, but that is for the rods that support the hydraulic cylinders for semimount plows, etc.
John M
01-30-2006 16:07:36
No,its not a demonstrator.I cant help on the hydraulics.
Andrew Z
01-30-2006 16:46:42
 Re: Could this be.. in reply to John M, 01-30-2006 16:07:36
I think that if you have a Stage II Super H you can not have a belly pump. My Stage II does not have any of the holes for the lines to come through. I also heard that it was not possible that with the larger clutch that it would not fit or something like that. I sounds like you might have a Stage I that came factory with the belly pump and someone added on a live pump. Andrew
