What to look for on H narrow front end wobble
Randy_NE
01-31-2006 13:25:44
I am sure there have been post on this but since the search does not work I need to ask.
Have lots of play in the steering, what do I need to look for from easiest to hardest fixes.
Randy
GWT
01-31-2006 17:34:15
 Re: What to look for on H narrow front end wobble in reply to Randy_NE, 01-31-2006 13:25:44
Randy, I got a lot of play out by just tightening on my 400. Most of it was at the top of the bolster. Just remember you're tightening against bearings.
Aces
01-31-2006 14:35:01
Randy Many things loose wheel bearing, loose or bad bearing on front of steering warm shaft. bad u joint on staeering shaft under hood, loose warm gear on bolster shaft, bad warm shaft, bad warm gear or both, bad bushings in the front bolster. Or all of the above. Start at the u joint and check every thing one at a time.
504
01-31-2006 20:47:25
 Re: What to look for on H narrow front end wobble in reply to Aces, 01-31-2006 14:35:01
Randy, This wont help the play but if you lower one front tire P.S.I. about 10P.S.I. it won`t shake as bad at hwy speed.
