Mag Switch
Elk Farmer
02-02-2006 15:45:54
Is there a way to put a switch to ground the mag out. My H now has a cable to pull which is rested so I have to get off the tractor to shut it down.
thanks
Elk Farmer
MagMan
02-02-2006 18:04:18
 Re: Mag Switch in reply to Elk Farmer, 02-02-2006 15:45:54
Hey there elk farmer thats no problem. Just take the two screws out of the part on the side of the mag unhook the cable. Then pull it off there should bea nut underneath with a hole tapped in it for a small screw bolt. If not I can send you one then hook a wire up to it run it back to the seat and you find an on and off pull switch and hook it up or any kind of switch that would ground to the tractor when you switch it. Or you can do what I do and just take the wire wrap it around the light and ground it when you want it to quit. I would really like one of those switches for my 40 H if you want to part with it. JON
Michael Soldan
02-02-2006 16:12:49
Elk Farmer, if you want to stay somewhat original, a choke cable assembly is probably around $10, just install it in the original brackets, will work just like an I-H one...Mike in Exeter Ontario
RustyFarmall
02-02-2006 15:51:40
IH did away with that cable arrangement and replaced it with a wire to a switch. This switch is available from somebody as a reproduction, and you will have to make some changes to the mag also,but it shouldn't be a problem.
