fuel leak wd-9
aaron morrison
02-04-2006 16:18:43
i have fuel leak inside injection pump filling up gov. housing i have replaced gasket behind primary pump any other ideas ?
Ron in Nebr
02-05-2006 00:04:14
 Re: fuel leak wd-9 in reply to aaron morrison, 02-04-2006 16:18:43
You more than likely have a bad seal on the shaft of the primary pump. New gasket between the primary and main pump wont fix it. The newer versions used a rubber seal which is still available from IH, but the older pumps used a packing seal which I dont think is available. Go to the Red Power website and make a post there asking for a guy that goes by the user name of MB_Cat....he's an expert on the old IH deisel pumps and can probably help you.
Ted in NE
02-04-2006 20:24:17
Could have a leaking seal on the transfer pump shaft. Is a double lip seal keeps fuel out of pump houseing @ oil from getting out of gov houseing into fuel. They get hard with age, also get some wear on shaft. Also could have the scavenger valve stuck, or bad oring on the valve sleeve. valve is behind the round plug with the screw slot on the side of the pump houseing.
