Order Farmall Cub Parts Online
CUB hydralic pump
PLOWPUSHER
02-07-2006 16:03:11
What is the correct way to replace the shaft seal on a 1948 farmall cub hydralic pump? Thank You.. PLOWPUSHER
Jim Becker
02-08-2006 18:43:41
 Re: CUB hydralic pump in reply to PLOWPUSHER, 02-07-2006 16:03:11
Early ones used a lip type seal, later ones an o-ring. So you are both right.
Denny ('60 Lo-Boy)
02-08-2006 11:15:02
I think the seal used on the shaft of the Cub pump is just an o-ring.
CNKS
02-07-2006 19:41:38
Pull the old out and install the new one with the lip facing the oil. You can use a block or a socket that matches the seal to drive it in with a hammer (gently). If the shaft has a groove in it you need a speedy sleeve.
