Order Farmall Cub Parts Online
Hydraulics on a 1949 cub
George the far
02-12-2006 12:51:11
I'm rebuilding the hydraulics (not the pump ) on a 1949 cub. I'm putting new "O" rings in the hydraulic housing and the manual says to use a twisting motion to install the piston with the new "O" rings. I've put fluid on them and even with a twisting motion I can not get it to go back in. Can anyone give me some ideas on how to compress the "O" ring so that I can get it back in? Help.
CNKS
02-12-2006 16:42:30
 Re: Hydraulics on a 1949 cub in reply to George the farmer, 02-12-2006 12:51:11
It will go, just make sure it's good and lubricated. You might put some fluid in the opening also. Assuming you are using the correct o-ring, it will go in. Try using a little grease. Did you get the CIH kit, or did someone size them for you--if they are not the ones in the kit, that might be your problem, although the o-rings themselves are available anywhere.
George the farmer
02-13-2006 06:24:39
 Re: Hydraulics on a 1949 cub in reply to CNKS, 02-12-2006 16:42:30
CNKS, The "O" rings are Case International and should be the right one's. I'll give it another try.Thanks for the advice. George
