quick fix wisconsn
all for school
02-15-2006 08:22:23
hello, i was wondering if anyone knew if a wisconsin VF4 could get started if i just put the gas tank higher then the carb. because i dont have much time to order a fuel pump. i know the farmall M works without a fuel pump, so if anyone knew if i held the tank higher then the carb if that would work thanks brandon
mark k
02-15-2006 21:07:32
 quick fix wisconsn in reply to all for school , 02-15-2006 08:22:23
Hello,
When I was trying to start mine for the 1st time I used the orig tank and a boat fuel bulb, I later found out it had a priming lever. I don't know whether it will flow through the pump or not. With the bulb you can push it through unless there is a hole in the diphram and it lets it run out the hole in the pump. Mark
El Toro
02-15-2006 09:28:35
 Re: quick fix wisconsn in reply to all for school , 02-15-2006 08:22:23
Be sure you have a shutoff valve at the tank along with a sediment bowl. Use can use a gas tank from an old garden tractor or large lawn mower that have these already installed. Hal
El Toro
02-15-2006 08:46:56
You need to use a fuel tank that is vented and hook the fuel line directly to the carburetor. As long as the fuel tank is slightly higher than the carburetor it will gravity feed to the carburetor. The same thing happens on these
tractors that have gasoline engine's. Hal
