H4 mag
shin
02-18-2006 20:11:45
Wrote from Japan.
Dear Sire
I have farmall super H.
Mostly, restoration of engine was finished.
But,dose not spark.I changed new point,rotor,and cap .
But,dose not spark.
I think that it is a thing with bad Coil,or poor contact.
Please let me know!!
El Toro
02-19-2006 04:28:37
 Re: H4 mag in reply to shin, 02-18-2006 20:11:45
Make sure your points are set at .013" (.33mm)
and use a cotton swab dipped in alcohol to clean the points. Hal
El Toro
02-19-2006 04:06:29
Remove the coil wire from cap and hold it within 1/8-1/4 inch (3-6mm) of a good ground on the tractor frame while someone attempts to start the tractor. You may want to use a pair of insulated pliers. Disconnect the kill wire from the mag for now. You should have a nice blue spark. If you have good spark when doing this your plug wires may be the problem. Use only plug wires with copper wire.
If there's no spark remove the coil cover and use a flat blade screwdriver to touch the magnets near the coil. They should pull the screwdriver with some effort. These are what generates spark in a mag when passing past the coil. If the magnets are ok, I think your coil may be weak.
Hal
shin
02-19-2006 05:34:08
 Re: H4 mag in reply to El Toro, 02-19-2006 04:06:29
Thanks your kindness. I try again.
I hope nice spark.
Thanks a lot,
shin
Bob
02-18-2006 21:02:58
Link to on-line mag manual:
http://www.cleancomputes.com/Cub/Blue%20Ribbon%20Service%20Manuals/GSS-5035%20Service%20Manual%20Magnetos/index.html
shin
02-18-2006 21:51:10
 Re: H4 mag in reply to Bob, 02-18-2006 21:02:58
Thank you Bob.
Yes, I had manual.
When it was made to remove and rotate from engine, it Sparked.
But,H4 mag on engine,dose'nt spark.
Bob
02-18-2006 21:54:11
 Re: H4 mag in reply to shin , 02-18-2006 21:51:10
Do you have the correct (rotation) mag for your engine?
Is it a mag that previously worked on that engine?
Have you verified that the mag is actually rotating with the engine?
When the mag is installed on the engine, is the "kill" wire connected to the mag?
shin1
02-19-2006 05:49:13
 Re: H4 mag in reply to Bob, 02-18-2006 21:54:11
Bob
Thanks,H4 mag is genuine for super H.
This tractor is my grand father's
After he stops operating, about ten years have passed. tractor is still in the state at that time.However, wiring had run out.
I have tried to restore for him who passed away.
Wayne Swenson
02-19-2006 07:57:00
 Re: H4 mag in reply to shin1, 02-19-2006 05:49:13
Shin: remove the shutoff wire attached to the mag. If it works, your problem is in the wiring. The wire is a grounding wire when you want to shut off the sparks; it must be insulated (not grounded) to run. You may have a faulty switch.
Good luck.
shin
02-19-2006 17:53:40
 Re: H4 mag in reply to Wayne Swenson, 02-19-2006 07:57:00
Wayne-Thanks your kindness.
I try again.
Thanks
shin
