Tweeter, What happened with shifter?
Janicholson
02-20-2006 06:23:32
I just wanted to know what ended up happening with the stuck trans,
JimN
Tweeter
02-20-2006 06:26:47
 Re: Tweeter, What happened with shifter? in reply to Janicholson, 02-20-2006 06:23:32
I took the shifter off and tried to move the slide with a big screwdriver but couldn"t do it. So, then I put the shifter back on and wiggled the shifter for a couple minutes and it just popped the slide out and everything is good now. Thanks.
Yugrotcart
02-20-2006 14:49:56
 Re: Tweeter, What happened with shifter? in reply to Tweeter, 02-20-2006 06:26:47
I had my W6 for about 6 months and a friend took it for a drive. Locked the tranny up tight. I was able to relign the rails through the shifter hole. Turns out the pin that holds the shifter in was worn giving the shifter too much play. Installed a new pin, no problems since,,,,, ,,,,
