'49(+-)International Harvester 340 Utility - Steer
sully sulliban
02-25-2006 16:25:57
Need assistance regarding the repair of the steering on my 340 Utility. (It has a front loader and a rear scraper blade.)
It is equipped with a power steering unit that was installed sometime after the tractor was manufactured.
I recently replaced the the power steering pump due to seal failure on the pump.
The P.S. pump is an early 70's or there-abouts and is belt driven from the crankshaft.
The steering seemed to work smoothly for twenty or so hours after the new pump was installed, then it developed a slightly erractic jerking when making turns to the left and right, requiring me to apply considerable pressure to complete the turn and to return the tires back to center. This action was more acute when the front bucket was loaded, but even with no load, the steering was still jerking.
Note: There was considerable free-play (about 1/4 turn in either direction) in the steering prior to the steering failure.
When the steering failed, there was no unusual noise, no difference in the feel - the steering wheel just began to turn very easily with no action from the front wheels.
I'm not sure if the power steering actuator connected to the steering sector box (located in the steering column) failed or the sector box itself failed or a combination of the two.
I am in need of an assembly manual and would appreciate any and all input regarding the steering situation on my tractor.
Thanks for reading and your assistance.
Sully.
email: sully3425@aaahawk.com
CHRISCO
02-25-2006 17:21:13
 Re: '49(+-)International Harvester 340 Utility - S in reply to sully sulliban, 02-25-2006 16:25:57
I HAD A SIMMULAR PROBLEM BUT MY POWER STEARING PUMP WAS PIGGY BACKED WITH THE REGULAR PUMP BUT I REPLACED THE PUMP AND IT WORKED FOR A WHILE AND FOUND OUT THERE WAS A SEAL CAUGHT IN TH PRESUER RELEAFE AND I REPLACED THE SEAL IN THE RACK CYL IF YOU HAVE ONE OR DO YOU HAVE A CYL?
