WD9 Crankshaft.
Grabatire
02-26-2006 22:40:54
I'm trying to resurect a 1951 WD9. The crank is toast. Will a crank from any of the other WD9's fit, or did IH make some changes along the way.
David Saville
02-27-2006 19:02:34
 Re: WD9 Crankshaft. in reply to Grabatire, 02-26-2006 22:40:54
I returned to the shop to look it up for you. Diesel engines before unit #18000 were not counterbalanced. To change over to the balanced crankshaft you need the newer connecting rods and bearings. It looks like the mains stay the same but there were two updates on the thrust main.
David Saville
02-27-2006 16:52:36
There was a change in the SWD9 on the crankshaft which only changed the front of the crank where the hand crank attaches. Look in a WD9 parts book, I am sure that there is a serial number break on the main bearings. I also think that at 1951 you are in the late group.
Ron in Nebr
02-27-2006 07:35:28
I may be wrong here so someone correct me if I am, but I think all the deisels used the same crank. The Super WD-9's, 600's, and 650's that had the larger 350ci engine just had a larger bore size.
El Toro
02-27-2006 04:01:13
The 600 and the 650 used the 350cid engine too. Hal
PS; There may have been more.
