PTOclutch gear
Dave in Va
03-03-2006 16:01:59
Will the clutch slid gear come out the back with the pto shaft and bearing ,or do i have to go all the way in to the transmission to get it out THANKS GUYS Dave inj Va
Bernard le mécano
03-06-2006 07:20:56
 Re: PTOclutch gear in reply to Dave in Va, 03-03-2006 16:01:59
Hi Dave, remove the lever assembly before, slide the collar on the rear shaft, then pull the shaft out. Be carefull to do not drop the collar when you pull the shaft. It have a bushing in the front of the shaft, check and replace with a new. Bernard le mécano Québec Canada
Haas
03-04-2006 17:22:06
I know nothing about the B275 tractor. I looked at the parts info I have, and it shows the PTO separate from the transmission so I can't tell if the PTO parts come out the back or not. Sorry. Maybe someone else will answer.
dave in va
03-05-2006 16:16:15
 Re: PTOclutch gear in reply to Haas, 03-04-2006 17:22:06
HEY THANKS MAN for your efforts,may try again later Dave in Va
Haas
03-03-2006 18:39:24
What tractor????
Dave in Va
03-04-2006 17:10:31
 Re: PTOclutch gear in reply to Haas, 03-03-2006 18:39:24
It,s a B275, Also the same as a B414 Thanks Dave
