Order Farmall Cub Parts Online
Farmall Cub belly mower removal
Jesse
03-13-2006 13:20:30
Maybe I am not the brightest guy in the world, but how do you remove the belt pulley from the PTO shaft. I removed the 2 bolts, I thought it might slide off. It won"t. Is it keyed? What am I missing?
billde
03-13-2006 14:17:53
 Re: Farmall Cub belly mower removal in reply to Jesse, 03-13-2006 13:20:30
If it is a taper lock there should be holes in the pulley that are tapped, and clearanced holes. the bolts you removed should have been in the clearanced holes. Screw the bolts into the threaded holes this will force the taper apart and release the hub from the shaft.
gene (missouri)
03-13-2006 14:15:51
Link
Peabody
03-13-2006 13:47:45
With a little persuasion, it should slide off. It is a compression fitting and those two bolts tighten the fitting as they are tightened. Try some penetrating lube and tapping with a hammer. With some prying it should come right off.
