Farmall M spark plugs
DJL
03-17-2006 19:31:46
Going to try and get back to SE Iowa, to the farm where I grew up, it's about 200 miles from where I live now. Dad's been trying to tinker around with an old M he has, hasn't ran for about 6 years, but has always been in the shed. I'm planning on pulling the tank off and cleaning out all the rust, putting in a new battery etc. Question is: I'd like to pick up some new spark plugs for it on my way. What plugs does a regular M take?
NDS
03-18-2006 18:49:05
 Re: Farmall M spark plugs in reply to DJL, 03-17-2006 19:31:46
Have run about every brand of plug in a lot of different tractors and have found that if you have reccomended heat range, tractor is not burning oil and fuel is adjusted right all of them work fine.
Mcred
03-18-2006 15:44:12
We use Champions in all of our tractors never a problem Id use D-18 thou the 21's have to hot of spark if you work them they will pre-ignight and run like crap and drive you in sain.
sammy the RED
03-18-2006 11:24:58
I have always used Champions in my two M's.
Lenny Kirby
03-18-2006 07:36:05
NO champions!!!!! Do what the Vet says...
CNKS
03-18-2006 13:14:30
 Re: Farmall M spark plugs in reply to Lenny Kirby, 03-18-2006 07:36:05
Used Champions, more than any other, never a problem -- I really think all the hype about Champions was started by some mythical Champion hater, the snowballed and got out of hand.
the tractor vet
03-17-2006 21:37:57
386 Autolites or C86 AC's set gap at .025. set points at .020 .
John *.?-!.* cub owner
03-17-2006 20:16:26
Try Champion D21
