Hydra-Touch and Crank Pulley Pump
Tweeter
03-18-2006 08:00:59
If I added a front mount hydraulic pump to my 330u, would I have to have a seperate reservoir and controls for that pump to work in tandem to the original gear pump on the side of the engine.
Janicholson
03-18-2006 20:05:40
 Re: Hydra-Touch and Crank Pulley Pump in reply to Tweeter, 03-18-2006 08:00:59
Hydraulic pumps should be seperate. If connected, they would increase the flow, but it would be beyond the design spec for the system and not happy at all.
Seperate is also more flexible for multiple applications used at the same time. Good luck,
jimN
