? for Haas and others on bearing #
banjo
03-18-2006 10:41:18
You gave me a number for the transmission bearing earlier. Is that a case/Ih number?49339D
do you have the numbers for the final drive and axle? I have the numbers that are on the original bearings and seals.Napa was no help here.basically i need all the seals and bearings for the final drives and transmission.
here are the numbers i pulled off the old ones.
Tranny,counter shaft, ( 49339D)bower- M1207E& M1207,IH GC-230, Main drive shaftIH C-235 & 0-230-T
Final Drive, IH ST-204,IH PL-240 Axle,IH L-250 Planter seal, national 264098R91 Final dr seals,C/R 51494DA & (43283-D in the aluminum housing).Is the latter one seperate or does it come with the aluminum housing?
I'm probably going to have to make a 160 mile round trip to a bearing place to find these, any help is appreciated.
banjo
03-18-2006 13:30:03
 Re: ? for Haas and others on bearing # in reply to banjo, 03-18-2006 10:41:18
Thanks, maybe i'll run across that site and can cross them myself.
Bob
03-18-2006 14:11:04
 Re: ? for Haas and others on bearing # in reply to banjo, 03-18-2006 13:30:03
Here's a site I have had luck with in the past. You MAY find some of your numbers their:
El Toro
03-18-2006 12:56:14
Chicago-Rawhide should be able to cross-reference
the seals. Here's their toll free number 1-800-882-0008. You can try advancebearings at 847-895-1111 or email them at sales@advancebearings.com.
Hal
Their web site is: Link
Haas
03-18-2006 12:54:28
I don't have time right now to research all this. HOwever, the 49339 D is an IH number. I can't recall the site, but found one sometime ago on the internet where you can put in numbers and get cross references. I have an old IH bearing cross reference manual that I can look in and maybe help you some. But it will be tomorrow before I can do that.
