350 Utility steering
WI. jim
03-18-2006 18:41:47
what tractors use this same gear box ?
300
03-19-2006 09:40:00
 Re: 350 Utility steering in reply to WI. jim, 03-18-2006 18:41:47
if you need a steering box I have 2 good ones off of a 300U & a 350U that are good & tight
tgrewing
03-08-2009 18:17:05
 Re: Farmall H Problems in reply to Farmall Bob, 03-01-2009 17:23:07
the distributor is great in terms of wear. the points set nicely together. i was getting 7 volts at the distributor, is that too much?
thanks
Friend of the farm
03-09-2009 15:23:03
 Re: International B-275 in reply to glmpa, 03-08-2009 15:37:42
I have a 1960 B 275, starts great if the glow plug are working properly if not I plug it in for a Hour at -20F. I have a 750 cranking Amp battery with an after market master switch installed because the tractor sits lots, only started about once a month in the winter to plow snow and the battery will drain.
TDK
03-18-2006 20:14:42
The 300, 330 & 350 utilities use the same gearbox. The 340 & 460 utility gearbox can be used also, but it will intefere with sediment bowl. The 340/460 box is also beefier.
