hydraulic pump pressure and fluid
john-wiz
03-19-2006 09:38:59
I have a farmall H with a hydraulic pump from a 300 mounted in front of the dist. I am re-doing the hydraulic system. Dous anyone know about how much pressure this pump makes and can I use dexron/mercon ATF fluid instead of hydraulic oil since it is thinner?
Quebec Red
03-19-2006 16:20:37
 Re: hydraulic pump pressure and fluid in reply to john-wiz, 03-19-2006 09:38:59
Pressure should be in the 1250 to 1400 lb. range. The higher you go the more $$ you will give to Mother Case. Lifting power also depends on cylinder diameter. That oil is , well, OK, as long as you do not contaminate oil being used in a newer tractor. Once your system is free of dirt and water, etc. I recommend HY-TRAN oil. It is superior and worth the money....QR..
Levi K
03-19-2006 09:52:14
well, when my 300 had the loader on it, It could raise the back end clear off the ground with 3 wheel weights on each wheel and tires full of fluid, I'd say they operate around 2500 lbs. Far as the oil, I don't know.
