farmall h bearing problem
gary alley
03-25-2006 15:25:07
I am restoring an H and have found a broken bearing carier that fits on the shaft that holds the the brake drum .Is this a common problem with the H and how easy is it to fin the carriers for both sides . I would appreciate any help on this .Thank you gary
Haas
03-25-2006 18:52:15
 Re: farmall h bearing problem in reply to gary alley, 03-25-2006 15:25:07
Someone probably tried to remove that flange without going into the transmission and taking the bull gear off the axle. That holder straddles the bull gear and can't be removed without taking the bull gear off the axle first. The brake drum shaft is an extension of the pinion shaft and gear that drives the bull gear. The pinion gear and shaft are all one piece. I have a new old stock bearing carrier, but I'm not sure which side it is for. I think the LH and RH are different. If you are interested, send me an E mail.
Nebraska Cowman
03-25-2006 16:10:13
I have just dismantled a couple.
sgtbull
03-26-2006 06:26:31
 Re: farmall h bearing problem in reply to Nebraska Cowman, 03-25-2006 16:10:13
Nebraska Cowman....you haven't happened to pull down any engines by any chance have you? I'm looking for a good idler gear (between the crank and gov. gear...and perhaps a good crank gear w/ little wear. let me know if you have one to peddle...thanks. Kelley.
