H spark plugs
Andrew Betzner
04-05-2006 15:31:30
I was wondering if anyone knew the new numbers for what spark plugs i need for an H. I have a manual but they changed the numbers. It has Autolite BT8's in now. What is the new number?
Dellbertt
04-08-2006 06:46:08
 Re: H spark plugs in reply to Andrew Betzner, 04-05-2006 15:31:30
AC Delco C-87
Deerely B Parted
04-06-2006 07:47:00
I read with certain interest (you comment)
that Autolite 388 plugs should not be used with a magneto ingition system. I bought a handfull of them the other day and now my F Cub and JD B run at the top their game. Is there any potential for damage if they are used? They sure worked fine for me!! Joe Howard
Glen in TX
04-05-2006 16:07:37
Autolite 377, 378 or 3116 and Champion D21, D23 or D18Y are non resistor plugs and will work. Autolite 386 & 388 will fit but keep in mind those are resistor type plugs and shouldn't be used with a magneto ignition.
Andrew Z
04-05-2006 15:56:57
I have good luck with the Champ D21"s in our H, and Super H. Andrew
