Rear Rim Size/Tire Size
Elk Farmer
04-08-2006 06:59:13
The numbers on the side of the tires on my H says 11.2/38 (on 10" rim) which are new. I'm looking at a set of use rims that have 12/38 tires on. Can I use the 12/38 rims with my 11.2/38 tires?
Thank You
Carl from Michigan
CNKS
04-08-2006 14:43:46
 Re: Rear Rim Size/Tire Size in reply to Elk Farmer, 04-08-2006 06:59:13
You need to measure your rims, and/or the other set you are looking at. What the tire says is the recommendation for that tire. It does not mean that they are actually mounted on that particular rim. I bet the rims you are looking at are ll inch. Are the tires actually 12-38, or 12.4-38. The old designation for 12.4-38 is 11-38. You can likely go one inch on either side of the rim designation without problems. Rim size 2 inches bigger than the tire size, no.
old
04-08-2006 09:19:41
My self I wouldn't. The rim is wider then the tire is and the side walls will stick out past the tread on the tire and really be hard on the tires. You need a set of 13.6 tires on those 12 inch rims
