IH 4 row planter - help with ID and adjustments
RC Farms
04-11-2006 06:18:46
I tried the emplement forum , no luck so I thought you IH folks could help me out. I have an older tool bar 4 IH planter that I need to ID so that I can find an owners manual. There are numbers on one side of the gear box, is that the model number? Also just right of the gear box is a small lever and a plate that has 1,2,3,4 settings...what does that do? How do I adjust the planter cans for 30" rows?
Thanks in advance,
Ron
Brownie 45
04-11-2006 17:39:34
 Re: IH 4 row planter - help with ID and adjustment in reply to RC Farms, 04-11-2006 06:18:46
Second thoughts, Could be a 450 planter.
Brownie 45
04-11-2006 11:26:45
The 1234 on the gearbox was used when power checking corn & it would drop 1,2,3. or 4 kernels per hill. If it is old enough, it may even have a wire check unit which would let the planter drop kernels at -usually 38 or 40 inches to make cross cultivating possible. Don't remember the planter number though. Might be a 424?
john d
04-11-2006 06:48:30
If you could get us a picture of it, someone can probably help you.
RC Farms
04-11-2006 08:26:39
 Re: IH 4 row planter - help with ID and adjustment in reply to john d, 04-11-2006 06:48:30
OK, thanks, I will take a picture of it and up load it on a another post.
