how much does a 560 weigh?
M. in sask
04-18-2006 15:46:54
Hello Does anyone know how much a 560 diesel weighs ? I am going to an auction sale and need to know if my car trailer will haul it Thanks Merv
Travis Harra
04-22-2006 21:58:50
 Re: how much does a 560 weigh? in reply to M. in sask, 04-18-2006 15:46:54
I have a 560 Diesel that I use year round. It is a narrow front, fast hitch, tires are not loaded, but i do have 5 sets of weights on it. it has 16x9x38 tires on it. With me on the seat it weighs right at 8,500 lbs.
K.B.-826
04-18-2006 17:06:56
Base weight for a diesel with zero options and no fuel or coolant was 5,960 lbs, which would already be pushing it for a car trailer with tandem 3,500 lb axles. Figure in coolant, fuel, and common options like PTO, TA, hydraulics, Fast-Hitch, and wide front, and you're at 7500 lbs easy. Add a full set of weights and fluid in the tires, and 10,000 lbs is very possible.
Lance R.
04-18-2006 16:33:46
Mine weighs 8,500 lbs with fast hitch, 15.5x38 loaded tires, heavy duty IH wide front with weight bracket and 400 lbs of weights, and a half tank of fuel. Hope this helps. Lance
THE TRACTOR VET
04-18-2006 15:48:51
Nope it can weigh in at over 10000 lbs with loaded tires and weights on it along with a wide ft. and all the trimmens
champspa
04-18-2006 16:47:43
 Re: how much does a 560 weigh? in reply to THE TRACTOR VET, 04-18-2006 15:48:51
should not be any problem to get in 7000 lb class
