5488 mfwd steering
1468 farmer
04-23-2006 08:40:06
Got a 5488 mfwd that turns very hard. I jacked it up nothing binding. I replaced the hand pump about 10 hours ago because of excessive steering wheel turn. Everything worked fine after that. It acts like its starving for oil. Thanks for your help
trick26
07-01-2006 11:08:04
 Re: 5488 mfwd steering in reply to 1468 farmer, 04-23-2006 08:40:06
hate to tell you but your power steering and lube pump combo is bad that is the back pump behind the right battery there is a big suction line on the bottom and 3 5/8 lines on top 2 to one pump and 1 to the other pump it is two pumps in one
