Shifter dissasembly
Chris(WA)
04-28-2006 07:38:06
Just got a Cub. Late model with the bent shift handle. Problem is the handle turns. I imagine the locating pin is busted or worn out. Had the shifter off the trans but do not see any obvious way to get it apart. What looks like the locating pin looks welded in place. (on the front of the housing where the shift pivots). The only other pin I see is under the spring on the shifter shaft. Rusted solid. Thought I would ask for advice before I resorted to trial and error. Thanks!
