oil leak on H under inspection plate
narrowfarm
05-10-2006 14:25:21
I would like to replace the both seals where the inspection plate is between the transmission & the hydraulic pump .Can i replace the 2 seals by removing the drive shaft for the hydraulic pump to get at the seals? Thanks narrowfarm
RustyFarmall
05-10-2006 14:32:00
 Re: oil leak on H under inspection plate in reply to narrowfarm, 05-10-2006 14:25:21
You will also need to drop the pump to get access to the tractors main driveshaft, it will need to be removed also. The belly pump is very heavy, you will probably need an assistant to drop it without injuring yourself or damaging the pump.
