M Lift-All
JimCEMA
05-11-2006 09:09:58
I have an M with a lift all. I want to use it with some newer equipment with hyd cylinders that I also use with newer tractors which run Hy-tran hyd fluid.
Can I run Hy-Tran hyd fluid in a lift-all instead of the recommended 30W motor oil?
Anyone done this? Problems?
Thanks
williamf
05-11-2006 14:15:04
 Re: M Lift-All in reply to JimCEMA, 05-11-2006 09:09:58
Some people say that the Liftall won't put out as much pressure with the lighter hydraulic oil. I've checked the one on my H with a gauge with hydraulic oil and with 30wt nondetergent and it read right at 750 psi both times.
Whatever's convenient.
Wm
RustyFarmall
05-11-2006 11:32:02
Hy-tran will work just fine in your Ms lift-all. In fact, if your other tractors were green, you could use whatever hydraulic fluid that is recommended for those tractors. Your lift-all won"t care.
dej(JED)
05-11-2006 09:31:35
The lift all uses a gear pump and it needs a heavier oil. The hytran ought to work okay. I have used hydraulic oil& odd motor oils. My M has the same liftall in it since I bought it in 1971.
