Switching to a 12 volt Delco Remy Generator
BOB1943
05-12-2006 03:36:48
Would like to switch over my Farmall 1941 H to a 12 volt generator and regulator - I do not want to use an alternator as I would have to cut the hood. Having trouble locating a any used or rebuilt 12 volt Delco Remy generator that might work. Everything was set up for 12 volts when I got the tractor except the generator/regulator itself. Looking for help.
River Bottom Farmer
05-12-2006 13:47:04
 Re: Switching to a 12 volt Delco Remy Generator in reply to BOB1943, 05-12-2006 03:36:48
If you still have the 6 volt generator you can take it to a rebuild shop and get 12 volt field coils put in it.Just had it done and it only cost me 140 dollars a fair price for good work I think and it charges perfectly.River Bottom Farmer
Janicholson
05-12-2006 06:32:23
Many (later)MDs, and 350Ds and other Diesels were Delco 12v pos ground systems. A 6v gen can be wound to 12v at a gen shop (call them first). Both Mitsubishi, and delco can be fit under the existing hood, search for pictures in the archives.
Good luck,
JimN
Nebraska Cowman
05-12-2006 04:11:18
You don't have to cut the hood to make an alternater fit. but I have had good luck getting the old 6 volt generator to put out 12 volts. I have an H and an M both running that way.
third party image
third party image
Even bad boys are just as good as they can be
JohnG(TX)
05-12-2006 12:00:21
 Re: Switching to a 12 volt Delco Remy Generator in reply to Nebraska Cowman, 05-12-2006 04:11:18
How did you do that? Just change the regulator? I have heard that would burn up the generator. How long have you run it this way? I might consider this since I have no lights and I am running a magneto, so there would be no steady-state draw, just what is required to trickle-charge the battery from the initial start.
gene bender
05-12-2006 16:41:34
 Re: Switching to a 12 volt Delco Remy Generator in reply to JohnG(TX), 05-12-2006 12:00:21
Looks like he is using the cutout and not a reg.
Nebraska Cowman
05-12-2006 15:32:29
I didn't change nothin, just grabbed an old genny off the shelf, Maybe I just "lucked out" but I have an M that I know when I got it had a 6 volt battery and I just put a 12 in and never changed a thing in it neither. go figure?
Easy
05-12-2006 18:01:31
 Re: Switching to a 12 volt Delco Remy Generator in reply to Nebraska Cowman, 05-12-2006 15:32:29
I did the same thing. The generator puts out volts. If you check it across the fields on the gen, before the regulator, it might be 20 + volts. Put a 12 volt regulator on it. You do need to reverse the polarity - the instructions come with the regulator. The starter will be fine.
BOB1943
05-12-2006 11:58:52
Did you switch to a 12 volt regular from the 6 volt
