Clean hys sys on 300u
Jimer
05-17-2006 15:44:50
The screen in my hyd reservoir was off, and I am wondering if there is any thing I should do to try to clean up the hyd system?
Janicholson
05-17-2006 20:01:20
 Re: Clean hys sys on 300u in reply to Jimer, 05-17-2006 15:44:50
If you replaced the fluid, it is probably OK. Using an aftermarket high flow filter in the return line to the pump can catch material before it gets into the pump. Flow should be 16GPM or so to reduce restriction on the intake. Taking it all apart, sucking out fluid and cleaning the bottom of the resivoir is another option, if you are rreeaall serious.
JimN
