12V Alt. for SA with Water Pump?
Jack in Ohio
05-17-2006 17:40:59
Does anyone know what 12 volt alternator fits on a Super A with a water pump? I put a water pump on my SA and it interferes with the Delco 2 wire alt. the previous owner had installed. I might have to make an adapter plate to raise the alt. so it won't hit the pump.
Thanks
Jack
Hugh MacKay
05-18-2006 01:23:53
 Re: 12V Alt. for SA with Water Pump? in reply to Jack in Ohio, 05-17-2006 17:40:59
Jack: If you put a double alternator pulley from 1980s GM V8 engines, it gives you space needed. By using the outer pulley this allows you to move the alternator back just enough to clear. On my tractor I just welded a flat plate on old generator mount and welded two tabs on plate for alternator mounting bolt to go through. Give yourself enough space to put a couple of washers between tabs and alternator, it gives you a chance to align belt better. Basically my alternator sits on that flat plate. My alternator also sits in within 1/2 of engine block with belt tight. I had to change the belt to one about 1" shorter.
If you want to e mail me I should have a decent photo scanned of this. I did SA, 130 and 140 all the same way, thus the photo you get may not be SA but they are all the same.
Jack in Ohio
05-18-2006 04:33:21
 Re: 12V Alt. for SA with Water Pump? in reply to Hugh MacKay, 05-18-2006 01:23:53
Thanks Hugh. I think I get your idea, if I need to I might email you.
Thanks
