Looking for info on an Internatial Tractor
Pooh Bear
05-18-2006 19:38:02
I posted a while back about this.
Link
I stopped by there today and got some numbers off the tractor.
He told me that since then he has found out the tractor is a D 188
Head Casting Number is 308378R8 (last digit could be a 3).
I found a little aluminum colored plate rivoted onto
the right side of the engine with these numbers on it.
11336 SXY-FF
He needs a head gasket for this tractor.
And he needs the torque specs for the head bolts.
And any other info he can get about this tractor.
Thanks.
Pooh Bear
El Toro
05-19-2006 03:11:04
 Re: Looking for info on an Internatial Tractor in reply to Pooh Bear, 05-18-2006 19:38:02
Your local Case/IH dealer may have the head gasket. You can try agkits.com or call them at 1-800-437-3609. Hal
TDK
05-18-2006 20:49:27
The D-188 diesel engine was only offered in the International & Farmall 504 and the 2504 Industrial tractor if I'm not mistaken. They were built between '62 and '68, 46 pto horsepower. According to the serial number you listed it's a '65 model. The letter suffixes mean - S = Torque Amplifier w/provision for Independent PTO, X = High Speed Low & Reverse Gears, Y = 12 G.P.M. Hyd. pump, FF = 4.5 G.P.M. Hyd. Pump. The head gasket number is 308379R3 and the torque for the head bolts are 75 - 80 ft. lbs.
Pooh Bear
05-18-2006 21:26:22
 Re: Looking for info on an Internatial Tractor in reply to TDK, 05-18-2006 20:49:27
Wow. Thanks a LOT.
I have an IT-FO4 manual for my 8N.
Is there a similar manual available for this tractor?
I"m amazed at the info I can get from this site.
Thank you very much.
Pooh Bear
TDK
05-18-2006 21:44:02
 Re: Looking for info on an Internatial Tractor in reply to Pooh Bear, 05-18-2006 21:26:22
You can get the IT manuals from this site. Click on manuals on the upper left corner of page. Search for IH/Farmall 504. I believe the manual number is IH - 201.
Pooh Bear
05-18-2006 22:30:50
 Re: Looking for info on an Internatial Tractor in reply to TDK, 05-18-2006 21:44:02
Thank you.
This will be a huge help for my friend to get his tractor running.
Can"t wait to tell him about this now.
Thanks so much for your help.
Pooh Bear
