improving '53 SC hydraulic controls
riverbend
05-27-2006 20:43:00
The hydraulic controls on my '53 SC are kind of pokey. Is there a way to sharpen up the response ?
I'd like to raise or lower the cultivators about 1/2" at a time, but there is quite a bit of lag time in the system i.e. moving the lever a small amount doesn't do anything. When it does move, it usually over shoots, leading to further adjustments, etc. Are there any straight forward fixes, or is that just the way they are ?
Thanks
Greg
RedJohn 2
05-31-2006 18:59:53
 Re: improving '53 SC hydraulic controls in reply to riverbend, 05-27-2006 20:43:00
Greg, You may get lucky and only have a fluid problem. Try draining the reservoir, remove and clean the reservoir filter very thoroughly, replace filter and fluid. Use Touch Control Fluid. After filling the reservoir, start tractor, operate hydraulics up & down 10 times (with fill plug still removed to allow any air to escape). Replace plug and cross fingers.
