Ticking sound in SMTA
BEL@IN
05-31-2006 14:34:30
I have a SMTA with power steering and it has a noise that seems hard to find. It is a continous ticking sound that seems to originate behind the oil filter. It changes with engine speed, and can be felt in the hydraulic lines. The priority valve seems ok, power steering ok. Any comments are appreciated.
Brownie 45
05-31-2006 18:18:30
 Re: Ticking sound in SMTA in reply to BEL@IN, 05-31-2006 14:34:30
If you feel like pulling the valve cover, you can check the valve lash to isolate tappet noise from other sources. You may just have a rocker arm that needs tightened a bit.
newpuller
05-31-2006 14:38:35
I have a 3' long piece of garden hose that I use as a stethoscope. It works like a champ at pin pointing ticking and clunking noises. These noises will travel through the metal but you can find the exact location of where it is in your tractor based on the volume of the noise, the closer you are the louder it will be.
