Opened up the B--What next?
bshannon
06-02-2006 15:33:52
Took the head off the B after weeks of soaking with various oils & fluids didn't do it. Cylinder #2 is kind of rusty looking. Block has been patched in the past & doesnt appear to be leaking. What's next, or should I consider it to be a parts machine?
El Toro
06-02-2006 16:49:47
 Re: Opened up the B--What next? in reply to bshannon, 06-02-2006 15:33:52
Unbolt one of the connecting rods and use a piece
of 2X2 oak to see if you can drive out the piston or the sleeve and piston. The sleeves aren't pressed into the block. Use can use an acetylene
torch to heat the sleeve once you get them removed. The old rods can be used on the new pistons. Hal
amo
06-02-2006 17:50:07
 Re: Opened up the B--What next? in reply to El Toro, 06-02-2006 16:49:47
it works just like you say. thanks amo
