OT: Hey Michael Soldan
Magman
06-04-2006 10:47:19
Hi Mike, Iw as wondering if you could help me ? My alfalfa that I planted last year is turning a milky browN whitish color on the tips mostly but working its way down. ANY IDEAS? jon
Michael Soldan
06-04-2006 13:08:33
 Re: OT: Hey Michael Soldan in reply to Magman, 06-04-2006 10:47:19
Hi Magman,what kind of weather have you just had? If the alfalfa has had a lot of wet it almost sounds like a leaf rot that could be air borne and I just checked alfalfa disease and I came up with "Southern Blight", a white cottony growth on the tips and stem with the plant turning brown. I have never experienced it myself but check "alfalfa disease" and do a search, it will give you some ideas about cause and I believe some remedy for it, there are several possibilities, let us know which one resembles your particular problem,sorry I can't be more help here but I have never had the problem, maybe Hugh McKay may have an idea, but the search will give you a lot of ideas, good luck..Mike in Exeter Ontario
Magman
06-04-2006 14:58:56
 Re: OT: Hey Michael Soldan in reply to Michael Soldan, 06-04-2006 13:08:33
I will have to check it better but I think like a blight It almost looks like frost damage. but I have never seen anything like this on grass. I am kinds wondering about the spray drift though. The neighbor has sprayed round up on his corn about 50 to 110 yards away in the last couple weeks. I will check it better and do some searching. I am in NY and the weather was warm and muggy last week and its been pretty good spring not to wet and not to alfull hot either.
Michael Soldan
06-04-2006 13:21:17
Sclerotinia is a fungus that can produce white mould spots on a plant, hot dry weather will help get rid of it. Wet weather, wet ground will accelerate the fungal disease, this is just another possibility...Mike in Exeter Ontario
Brownie 45
06-04-2006 12:19:48
Could be spray drift or might be leaf hoppers. Leaf hoppers generally turn leaves yellow- brown though. A few years ago, we had Command damage- which turns leaves white. Of course, it also turned the horseweeds white.
Magman
06-04-2006 17:15:03
 Re: OT: Hey Michael Soldan (BUGS) in reply to Brownie 45, 06-04-2006 12:19:48
Well I finally got off the tractor and looked close and it was eaten. The brown and white spots are from the plant dying where it was eaten
. DARN LITTLE CRITTERS. jon
