Where's the throwout bearing grease tube? (part II
RonFromCT
06-08-2006 19:07:35
Hopefully this message will save someone else a ton of trouble. After spending countless hours looking for the clutch throwout bearing grease zerk on my 1940 M, I got some good advice from this board that it had probably "backed out" and fallen to the bottom of the clutch housing.
Soooo, after purchasing another tube from an old M, I went to work trying to figure out how to put the darn thing in. No matter what I tried, threads wouldn't catch. Working through that tiny hole didn't help matters any, either. Then I did some careful looking and cleaning with q-tips (all through the 1" hole) and figured that the old tube didn't back out, but had broken off! A quick trip to the hardware store for an easy-out and 2 minutes later I had the offending piece in my hand.
Still can't put the new one in since I can't get the threads to go straight in (the hole is off center a bit, which is probably why the old one broke off), but at least I could install a flexible 1/8 grease tube from my grease gun and give it a good shot. I figure I'll install the new tube someday when I have to do some clutch work or have the belly pump off.
All in all, this has taken me over 2 months to get this stupid bearing greased. Probably won't do much good as I'm sure it's been dry as a bone for years, but this became personal and I wasn't going to lose.
Slappy
06-09-2006 03:35:52
 Re: Where's the throwout bearing grease tube? (par in reply to RonFromCT, 06-08-2006 19:07:35
I had the same problem on my H, but the H has a plate that can be removed to give a bit more room to work, so I had no problem getting the new tube in. The one that drove me nuts was the pilot bearing - the flywheel on was supposed to have a recessed zerk to grease the bearing, but after looking and cleaning and looking again I couldn"t find one. Turns out that the flywheel had been replaced with one out of a Super H. The SH flywheel is bigger and does not have the grease fitting.
To add to an already long post - I put a Super H head, cam, and step-head pistons into the old gal when I rebuilt her last year and so was greatful for the larger SH clutch.
ghumba
06-08-2006 19:19:19
Thanks for the info.
