DT466 valve lash
darksearth
06-11-2006 07:07:54
I'm trying to find out what valves i can set with the #1 piston at TDC and with the #6 at TDC.
The bock I have says valves 1,2,3,6,7,and 10 with #1 at TDC but 7 and 10 are open.
darksearth
06-11-2006 15:04:46
 Re: DT466 valve lash in reply to darksearth, 06-11-2006 07:07:54
thanks Ill cheak the flywheel
MN Scott
06-11-2006 10:05:43
My book shows at No. 1 TDC. 1 2 3 6 7 10. and 6 at TDC, 4 5 8 9 11 12. Which timeing marks are you using? Sometimes the balancer ring can slip you should confirm with the marks on the flywheel.
