12 Volt Conversion Resistor
Duane WI
06-15-2006 05:48:55
I am converting my Super C to 12 volt alternator. What type of balast resistor do I need to put in line with the ignition coil? Do I just walk into NAPA and ask for a balast resistor or is there a particular size or number? Thanks for the help.
Duane WI
06-15-2006 07:10:05
 Re: 12 Volt Conversion Resistor in reply to Duane WI, 06-15-2006 05:48:55
Thanks for the help
souNdguy
06-15-2006 06:45:51
Another number that you can cross is 8NE10306 that's a converting resistor...
however.. save yourself mucho headache's... when you are in napa.. just ask for IC14SB... it's a new genuine .. real 12v ignition coil.. NO RESISTOR NEEDED. It does not have an internal resistor.. it's primary winding simply has the correct gauge nd length of wire to be 3 ohms...
Cost about 15$...
Soundguy
John T
06-15-2006 06:40:21
Duane, a typical rating for a conventional straight (NOT a heat sensitive variable resistance Thermistor) Ignition Ballast Resistor is around 1.5 to 1.85 ohms. Ideally, to serve as a pure 50/50 static voltage divider to drop 12.6 battery volts in half leaving 6.3 across the coil, it would be somewhere near the same ohms as the coils primary (measured between its lil + and - terminals). The thing youre wanting to do to
prevent premature burning up of the points and not overheat the coil is to limit the coil/points current to around 4 amps or so, which at 12 volts requires around 3+ ohms of TOTAL (coil + Ballast) resistance in the ignition primary circuit. With that alternator, the battery voltage may run a lil higher then using a genny, so a lil over 3 ohms TOTAL (coil + ballast) ignition primary resistance is what I would use to extend point life and not run the coil too warm..... . The correct answer to your question really requires you know the coils primary resistance, but this ought to get you in the ball park and the spark should still be sufficient if you err slightly on the safer (more ballast) less current side of these suggestions. If this info is correct ?? (copied it somewhere from a YT Mag post)
NAPA # ICR-13 or Standard Ignition # RU-10 are rated @ about 1.77 Ohms to 1.87 Ohms
Other sources are Tractor Supply or Rural King etc.
Wire it in series ahead of the coil after the ignition switch and youre good to go. The alternative would be to buy a full 12 volt rated (internally ballasted) coil that requires no external ballast but the ballast is cheaper.
John T
Bob M
06-15-2006 06:20:01
Duane - Ask for a NAPA part #ECHICR13.
Wayne Swenson
06-15-2006 06:03:53
Ask for one from a "60"s Chrysler product.
They are just what you need.
I have an extra one, if you cannot find any.
muggsw6
06-15-2006 05:56:11
In my experience, all ballast resistors are pretty much the same. hth Mark
