I H 460
Brian Zimmerman
06-19-2006 20:09:42
can anyone tell me what psi the hydraulic pump puts out on a 460?
Broomstacker
06-20-2006 11:12:46
 Re: I H 460 in reply to Brian Zimmerman, 06-19-2006 20:09:42
My 460 Shop manual reads as follows:
"TESTING the PUMP:
Using a pressure guage of at least 3000psi, start the engine; Move a control valve to a raise or lower position. Watch the pressure. When it reaches 900 to 1200psi, the control valve handle should automatically return to neutral. With the lever held in the raise (or lower) position, prevented from moving to neutral, the pressure should reach 1200 to 1500psi."
src
06-20-2006 05:34:42
Most of them used the 12 GPM pump. A 17 GPM pump was optional, but you usually find those on industrial tractors.
