Att John A and River Bottom Farmer
Tom Windsor
06-20-2006 19:09:08
I told you I was going to set it on fire. Tonight I went out there and put diesel in each hole and fired it up. Let it burn out in about 30 minutes. Bottom line, I have 4 pistons and rods lying on my work bench...not stuck anymore..I had one broken sleeve attributable to stupid...buy you cannot cure that and ugly.
TW
John A.
06-20-2006 21:27:45
 Re: Att John A and River Bottom Farmer in reply to Tom Windsor, 06-20-2006 19:09:08
Tom, I am surenough glad to hear that!!!. The folks talk about different soaking concoctitions, (snakeoil) most of the time. Everyone I know who has done this has had basically the same results. It works quick, it is easy, doesn't require all thaat much beating with a 4x4 & 4lb hammer to get out.
All one needs is to use a little common sence and away you go. Keep us posted on you progress, Pics would be nice! Good Luck.
Later,
John A.
River Bottom Farmer
06-20-2006 19:46:55
Tom I am glad to hear of you progress.Now when is the overhaul kit coming?Another question,is the crank still standard spec.If it is I have a set of standard rod and mains I bought from the local Case IH dealer,CNH original not aftermarket.I would sell them to you for a fair price if you are interested drop me an email and we will work it out.I will be more than fair with you,I would like to see you get some use out of them.Let me know and good luck with your H.You will enjoy it alot when its done....RBF
