A and B both smoking
KRUSS
06-21-2006 06:29:42
For the first time since spring I found some time for my A B and C. The A and B are smoking at idle, (both started OK), they still smoke when warmed up. To me they sound OK. Do I have a simple carb adjustment needed or do I need to be setting some valve clearances.
John T
06-21-2006 06:49:31
 Re: A and B both smoking in reply to KRUSS, 06-21-2006 06:29:42
Is the smoke black or blue???
Black is excess unburned fuel from running the carb too rich or a high float level or a choke thats not fully opened or restrictions in the air cleaner or inlet air piping etc. Usually if they throw black smoke the plugs will carbon n gas foul also. Plugs that have an even flat black colored sooty coating is indicative of excess over rich fuel operation.
Blue is oil burning from worn or stuck rings or valve guides. Plugs with an uneven shiny black wet looking deposit is more indicative of oil burning
If a tractor sets a long time and the rings get stuck/carboned I run Rislone,,,,, plus Auto Tranny Fluid,,,,, ,,,, plus high detergent light weight oil in them and work them hot n long n hard under a heavy load, which may clean n free up the rings.
John T
Loren
06-21-2006 17:01:45
 Re: A and B both smoking in reply to John T, 06-21-2006 06:49:31
Kruss, someone didn't slip your chainsaw fuel in there did they? :>)
KRUSS
06-22-2006 06:14:57
 Re: A and B both smoking in reply to Loren, 06-21-2006 17:01:45
That very thought has occurred to me. I will fill the tank before I do much else. Did get the B so it's OK.
