Champion Plugs
IndianaMike
06-27-2006 09:46:17
For all of you out there who are still skeptical about the benefits of autolite over champion spark plugs, here it from me, Champion plugs are junk. I just replaced brand-new champion plugs with autolite and my f-20 runs better than it ever did, stronger and smoother. Don't fool around with the champion ones.
scotc
06-29-2006 05:06:50
 Re: Champion Plugs in reply to IndianaMike, 06-27-2006 09:46:17
I had an 87 dakota with the (in)famous 2.2 engine that burned some oil. I had to get the engine hot or the plugs fouled and cleaning them did no good. Went to the auto parts store and asked if I should get a hotter plug or a different brand and he got me a set of autolights. I ran those for six months with no trouble but changed them due to the amount of oil i used. The champions just seem to go bad when there is oil present in the cylinders.
scotc
06-29-2006 05:10:45
 Re: Champion Plugs in reply to scotc, 06-29-2006 05:06:50
That was 5 or 6 sets of rn12yc's too, I finally beat my dad to the parts store when the last champions went bad. He wouldn't say anything about them fouling out so quick just kept buying more.
City-Boy McCoy
06-28-2006 05:02:52
Well, based on what you fellows have said, I think I"m going to try an AC, an Autolite, a Champion and an NGK - one in each cylinder! mike
NDS
06-28-2006 09:07:58
 Re: Champion Plugs in reply to City-Boy McCoy, 06-28-2006 05:02:52
If they are correct plugs it will run just fine provided everything else is correct.
City-Boy McCoy
06-29-2006 03:50:33
 Re: Champion Plugs in reply to NDS, 06-28-2006 09:07:58
Well, I was really kidding about that. But, I have heard these sparkplug preference discussions for years - and I really enjoy them. Here's a couple:
NGK = "No Good Kind"
AC = "Almost Champion"
mike
sammy the RED
06-27-2006 22:07:34
I have had the same set of Champion spark plugs in my Super M-TA for over 10 years. Some years worked over 200 acres with it. Still running good.
Rob Baird
06-27-2006 20:54:40
HI I worked in a garage we stocked all 3 plugs used ac in gm autolite in ford champion was chrysler although sometimeds used autolite in chrysler Use whatever works best for you I have run across some things that did like one plug better than another but all are usually good
Dave Sherburne NY
06-27-2006 17:14:14
Had a John Deere baler with a Wisconsin Engine
on it once. Put the proper new Champion Plugs in it and it would start right up.....BUT ONLY ONCE.
Changed to AC, and it started good first time and every time.
CNKS
06-27-2006 17:13:13
I should be smart enough to stay out of plug wars, but I have had more Champions than any other brand, never a problem. As stated below, get the correct heat range, and make sure your tractor is tuned properly -- then any major brand of plug is fine. The plug thing is a perpetual myth. Sort of like detergent vs non detergent oil, or lead additives in gas, etc,etc.
NDS
06-27-2006 12:50:11
You may be right but I have run thousands of hours using AC, Autolite and Champion plugs and in my opinion all of them are fine if they are correct heat range, gapped right, tractor is not using excessive oil and carburation is right.
Roger46
06-27-2006 19:45:42
 Re: Champion Plugs in reply to NDS, 06-27-2006 12:50:11
I am always amazed how people make a judgement on some something with one bad data point. I agree that all spark plugs are good as NDS said if you use them properly (right heat range and gapping). I remember my dad always said Autolite spark plugs were no good. I really never knew why.
gene bender
06-27-2006 16:27:38
GREAT CALL NDS i will buy that
Duanes
06-27-2006 12:29:03
Always have had very good luck with Champions.
ryan from WI
06-27-2006 10:51:11
You are right champs are junk.
Vacherie
06-27-2006 19:13:49
 Re: Champion Plugs in reply to ryan from WI , 06-27-2006 10:51:11
I have been hearing Champions are junk for 50 years. It's amazing they are still selling them.
CNKS
06-27-2006 19:24:43
 Re: Champion Plugs in reply to Vacherie, 06-27-2006 19:13:49
Yes I first heard it 20 years ago. Mechanic couldn't get my pickup to idle right, also had a flat spot under acceleration. He blamed the Champion plugs. So I changed them -- no difference. Rumors die hard.
